That is not where you limit the file size, you inadvertently limited the size of the new folder to 1 GB, and since it set to delete you only have a few minutes of recorded video. Set it back to 95% you're available free space. the file size limit is set in the record tab of each cameraHi all I need your help here how can I Convert 6GB .BVR to MP4?
Sooy but I am learning now I need to have small files, so I change the config to have 1GB Files.
If New and Stored are in the same drive then I’d personally not bother moving to Stored.
You have also set Stored to move to Stored?
Also interested in why you need to convert the clips to MP4
So you just need to export the clips of interest not set it up to do it all the time?
