The wires are still sticking out past the connector.Just started doing my own cables; the wifi signal in our house can be a bit patchy so I decided to make a wired connection to my TV; with Wifi, it kept losing signal, wired connection is much better!
My first effort was okay-ish; the wires went in fine, but when I went to cut off the ends after the plug it affected the No. 1 connection (Orange/white). While the tester said all was fine I still had to cut the rest of the wires shorter, thats what distorted the first connection.View attachment 177436
Those wire ends dont look very good and No.1 connection is a bit sorry for itself.
I decided to do this plug again.
THIS TIME, I prepared the wires in the normal way, got it all set up and pushed the wires in - I must say these pass through RJ45's are brilliant! They take all the guess work out of a rather tricky operation (if your hands are large like mine it can make it tough, and if they are prone to the shakes! Wires are fine, all in the right order; I then cut off the extra as close to the plug as possible, pulled the plug forward a tiny bit over the cut wire ends and 'Crimp'! I'm alot happier with this, no bent contacts, neater and tests out perfectly.
Much better and with a tiny bit of further improvement in future but this is far better than my first result by miles! Next time I can pull the plug forwards a tiny bit more.
It was after reading through this thread that gave me a bit more confidence on what to do and how to achieve it, so thanks to all!Cheers guys!
Best way I found with the pass-thrus is to push all wires out past the connector, then snip all parallel to the connector, then pull back cable so wires are just inside the connector. Then crimp.
Cheers guys!
