- May 13, 2015
- 507
- 76
if you dont post your settings, its pointless.What do you set in the trigger to improve triggers at night?
I have a camera that's mounted 12ft high pointing down that I can't get to trigger from 5 feet away when it's dark with only the IR running. Not sure where to adjust this. View attachment 33874
its not about the object exceeds percentage. dont mess with that.thanks.. this is good to know, I just started to play with zones recently so still learning. I'll reduce it to 30% or something
also, try reduce the minimum object size, contrast and especially duration.
.7 sec is kinda long... i run my cams at .2 or .3 secs...
I believe the Guassian/Simple setting can not be set per profile. So if you set it, it will be for all profiles !At night time, I recommend turning on "Black & White", turn off "Cancel Shadows", and choose Gaussian algorithm with "High Definition" checked.
