- Nov 1, 2014
- 1,830
- 1,190
At the house we are renting, the previous renter had alarm installed before he moved out. I think it ADT alarm system. This house is very old and we are most likely be the last people to rent because all the houses in the block are being torn down as folks moved out. I think they managed to get this block zoned for commercial purposes and land probably worth 100 times more than the houses on it.
Anyway I know landlord won't care if I take all the alarm system with me when we move out so I pulled off one of the PIR sensor off the wall and looked at the model number. It is a Honeywell 5800PIR-RES sensor, We have a bunch of those in the house and a main alarm box downstairs but it unplugged right now and a couple of door trip sensors on some of the doors.
I am in the middle of building my first home automation using z-wave, I am wondering is there a way to link those sensors home automation wirelessly. Or a device that link both together? I am sure it not a z-wave sensor but it would be nice to save myself a few bucks if I can uses those. There also a keypad however I am sure it firmware locked to ADT or one of the alarm company.
Is there a way to make it work?
Thank you
Bill
Thank you
Bill
