G'Day All
Need some guidance as I recently picked up 10 of these IP cameras and a Pacom SmartIP 16PM NVR from being dumped in ewaste and trying to get them to play nice with each other nut has me stumped. I am assuming majority of IP cameras and NVR's can communicate with each so I thought I'd drop in and ask here for some assistance in getting them working.
OK, so I've defaulted the Honeywell Camera and its default IP was 192.168.1.108, which points to being a Dahua made unit based in info I have from the "cliff notes" found here. I can log into the IP camera using a PoE Switch to the computer and logged into the camera via web browser and checked the TCP settings and enabled RTSP and ONVIF. Set a Static IP and rebooted camera.
Now when I connect the IP Camera to the NVR POE ports and use the NVR GUI to register the single connected cameras, nothing is found.
When I try to use the Third Party Scan option in the NVR, which has a few protocols to search from exampple , Axis, Panasonic WV, ONVIF Conformance & UDP, I have tried all these via entering the static IP address I assigned to the IP camera and the UDP port number but sadly none of these seem to find the a camera connected as if its not seeing the camera. Unfortunately, I do not have any other camera's to test the NVR ability to scan for cameras, however I can see in the NVR options & ettings the POE port is active and shows power consuption of a few watts. So I assume it's powering up the IP camera fine, but cannot find or get it to connect or talk to eachother?
Given I have exhuasted trying to connect these, am I simply SOOL in getting the NVR to talk to the IP Camera or do I need to make additional changes to the Honeywell camera network settings?
Apprecite any assitance
PEACE
Kosti
PEACE
Kosti
