Honeywell 16 channel 35 series nvr , 1- 16 port POE switch and 32 ip cameras. All except 5 are connecting and showing up. Looks like there are ip conflicts for the cameras. I changed the camera ip in the nvr and also tried using the unified tool to change the camera ip but neither one is actually changing the ip on the camera and saving it, Once the ip changes on the nvr interface it will do a search and want to add the camera again with the same old ip address. The unified tool shows the ip address as changed but will show up on the nvr with the old conflict ip.
Not sure what else to try, I can ping the camera ip's and can connect tot eh camera using the unified tool and see video.
