Thanks for the reply and the tip! I have installed many Honeywell vista systems back 20 yrs ago, so it may all come back to me once I open up the programming guide, (I hope). As for ordering the equipment, I have a account at ADI global and there prices seem ok. I will check ebay though. A friend of a friend just built a new house to flip and the electricians ran security wire also. front door(recessed), patio door, overhead garage door, back door garage, 2 glass breaks upstairs, 3 keypads, and a indoor siren. nothing fancy. I figured I would only get 1 x 6160 for ease of programming as they are $130 CAD ea. whereas the 6150 is only $60.00. I will suggest all 3 to be 6160's and I will definitely let you know if i have issues. Thanks again.Yes you can. Just make sure you assign each keypad its own address (ex. 6160 set to address 16, 1st 6150 address 17, 2nd 6150 address 18). You can get 6160's at a fairly reasonable price on eBay, why not just use all 6160's? I'm not a fan of the fixed display keypads like the 6150's.
These are basic questions that you should know that answer to if you're installing this system. I suggest you fully read over the programming guide and installation manual before you install it.
How many devices are you going to install on this system and will it include fire and CO? Also, are you going to be using wireless sensors?
Let us know if you need any additional help.
Yep, M-I-L got AT&T uVerse at her place 5 years ago, decent Internet speed but phone is VOIP, can't dial out/ ring in if no local utility power. An external UPS or an internal battery on the Pace 5268 router/modem may allow it to work, depending on how/where the power's out, but that's more crap to maintain.POTS lines will be completely decommissioned here in the US by this fall from what I've seen. No more copper lines.
