Hi everyone! Found this forum a few weeks ago and just can't get enough! I am a long time geek and have dabbled a bit in IP cams in the past. Just purchased a home in rural Washington and going down the rabbit hole of ip cams and home security options. Came across IpCamTalk forums when searching for NVRs and camera specs since our upstream internet bandwidth is not great and I realized that I would be better off with a local server solution. Love all the camera reviews and community engagement here on the forum. I am Currently looking to obtain full cam coverage around our home (maybe 10-12 cams). Here is where I am at:
Working with local security vendors to revive the Vista 20p hardwired security system (if you have recommendations for UL monitoring, send them my way!)
Trying to find an electrician to install security lights (I would love to be able to remotely turn them on, but have them either dimmed or on motion detection by default)
Read through most of the cliff notes
Decided to go POE all the way and picked up my first POE+ switch
Purchased some outdoor rated CAT6
Leaning towards mostly turrets
Purchased 2 4mp varifocal IPC-T5442T-ZE from Andy on Amazon and some of the soffit and wall mounts.
Purchased and started setting up BI.
I have reached an inflection point where I am starting to 2nd guess my camera choices. I know that I will likely need different focal lengths for different locations. The area around my home is pitch black at night and I am not sure when I will be able to afford to have the security lights installed, so trying to ensure I get the best low light bang for the buck.
I was super-impressed with the recent review on the EmpireTech 4k X camera with the 1/1.2" sensor. Wish that one was available as a turret! Since I don't think I need varifocal for every cam, also starting to look at these cams:
Loryta Outdoor Security 4MP Ultra Low Light Starlight+ WDR IR Turret AI IP Camera, Fixed Lens IPC-T5442TM-AS 3.6mm
EmpireTech Security Surveillance Camera 4 MP ColorVu Fixed Turret Colorful Camera DS-2CD2347G2-LU 6MM English Version
I know these are different focal lengths - thinking about ordering both to check them out.
What do you all think about the camera's with built in illuminators? Wondering if those will be helpful while I am waiting for my lights to be installed?
Also, any thoughts about 3.6mm vs 6mm for general use?
And finally, I am leaning toward Dahua but wanted to get everyone's thoughts about Hikvision cams - I see that Andy sells both.
