Hello,
I have a problem. I have HiWatch HWN-2108H-8P and IP Cam HiWatch HWI-B140H (2.8mm).
I set the nvr - password and so on... then I have connection to my internet router and IP cam to POE connector... I see that the cam is in POE in settings and power comsumpiton about 3-5W but I cannot to add the cam because I dont see the cam in any option - i am trying to add cam and try to search but the cam I see nowhere.
But if I connect the cam to external POE and the externat POE to internet router I see the cam in NVR and I can see the video and so on...
But I dont know why if I connect cam to direct to POE connection on NVR it is doesnt possible to add cam...
Can you help me?
thank you
Can you help me?
thank you
