Got a PTZ-camera Hikvision Hiwatch DS-P2420 PTZ-camera from a client. Had some symptoms ealier, camera went unresponsive and only way to get it running again was using SADP and activate it again and putting all the settings in.
It worked well for months, but then after reboot camera went unresponsive again. Now activation with SADP does not work anymore. After setting password and clicking activate, SADP says "device rejected". Still, clicking refresh in the list, camera seems to be activated anyway.
Changing IP static wont work, but changing to DHCP works, although camera says "time out", but still after that shows new got via DHCP on the list.
Trying to go web ui with that IP won't work, just can't load the web page. Ping works.
IVMS, Batch configurator, all of them have been tested, but none of them can connect with the camera. Once I plug it off from PoE, camera seems to forget its settings and return inactive once I plug it back again.
Different PoE injector / switch tested, also direct 12V. No help.
Inside the camera red led is blinking 1 times per 2 second. Reset button does not help.
Any ideas? Does this have memory battery?
