I have recently purchased a new PTZ dome camera from Chinavision (CVYY-I411, the brand is Hi3507 Hisilicon, device type RS7507H). The camera can be accessed with Internet Explorer, after installation of an ActiveX widget RSAV.exe. Inside the camera are several dip switches, which I left at default settings: baud rate 2400 bps, dome address code: 1, control protocol: PELCO-D self adaption.
The camera is connected by LAN to the router, a Vigor Draytek router 2700. Inside the LAN the camera is accessible without problems.
The camera has default settings for ports HTTP: 80, RTSP: 554, RCFG: 8001. As I have several other IP cameras connected, I opened for every camera separate HTTP-ports starting 1080, every camera has fixed IP, DHCP is unchecked. All existing IP cameras can be accessed inside the LAN or from outside without any problem.
For the existing cameras I did not need port redirection, only the corresponding open port in the router, to have access over the Internet to the camera.
With the new dome camera I also tried public HTTP-port forwarding to the private port, the same for RTSP and RCFG-ports, with no change. Inside the LAN the camera can be accessed without problems, but not over the Internet.
The problem is not related to the router, I tried with another router from AVM, unfortunately always the same result: the existing cameras have access by LAN and over Internet, the new dome camera can only be accessed inside the LAN.
Anyone has an idea, what might cause this camera, not to be accessed from outside the LAN ? Any help is highly appreciated, thanks all
