HiSilicon Backdoor
SouthernYankee
5,182
5,355
Houston Tx
The HiSilicon chip used in NVRs, DVR, cameras has a backdoor.
Hello
This article is already a little outdated, moreover, this vulnerability has been known for a long time. But opening Telnet is a small problem, but the fact that you can connect to almost any XMEye camera without a password is a lot more fun)
Just to avoid any confusion (as the HiSilicon chips are extensively used) the vulnerability is in the Xiongmaitech firmware, not the chip itself.
The XM firmware is riddled with vulnerabilities that can be easily exploited, it's the least security-conscious firmware I've seen.
Adding this at the built-in placeholder helps :
Code:
extapp.sh holds this :
#! /bin/sh
# An extra startup script to gain access to the internals of this DVR
# Need the delay to avoid dvrhelper killing telnetd when launching sofia
/sbin/getty -L ttyS000 115200 vt100 -l /bin/sh -I "Auto login as root ..." &
sleep 5
/bin/busybox telnetd -l /bin/sh &
exit 0
Doesn't even need the hard-coded well-known hash.
I agree, but on new firmware they closed port 23, which was previously open. Now port 9530 is responsible for Telnet, but it only responds to certain commands, that is, if you just try to connect to the camera or NVR with this port, you will get an error. However, the XMEye firmware is very unstable and always surprises with new glitches
Yeah - and they didn't do a great job of locking that change down either :
Yes, it's all over the place.
Like their cameras.
