I'm looking at purchasing a CCTV NVR and camera kit for internal monitoring during live events. I really only need it to monitor indoors for casual checking to make sure everything is good. It will be for viewing only and not recording (although i may add a hdd to be able to record at somepoint should we require it).
I'm looking at getting a budget hilook system but i have the following concerns.
i'm looking at getting something like this:
www.jmcsecure.co.uk
or this one:
ebay.co.uk
Any advice really appreciated thank you!!
- Can i view hilook on chrome or is it still not working with the NPAPI support issue
- What is the best way to monitor it multiple tv's around the venue. Ideally I was hoping to use the inbuilt browsers in tv's to view but i'm guessing the first point will render that not working?
Complete Systems
We appreciate it's not easy to know exactly what you need to make up a complete CCTV system. So we have put together a selection of products into Complete Systems. These contain everything you need to self install your CCTV security solution.
or this one:
ebay.co.uk
