Stupid question from a newbie.
Do I need the camera admin password to connect it to an NVR?
I bought a Hikvision DS-7600 series NVR to use it with an Acti E73 IP CameraI bought a few years ago.
This is what I done so far:
When I click OK that NVR wont recognize the camera. Is the problem due to the password?
If so I forgot the login credentials and I'm unable to login. Already tried defaults.
What can I do so I do waste my $USD 500 camera
Thanks in advance.
- I connected the camera directly to the network using an PoE switch and I’was able to find its IP address using a PC.
- In the Hik NVR menu I have included the IP address and selected Acti for the protocol.
- Changed the "Managenent Port" number to whatever number I set up for port forwarding in my router.
- There is a field for the camera username and password and I have left this blank.
Thanks in advance.
