HikvisionDS-2CD2387G2-L(U) or DS‑2CD2347G2H‑LIU
Mar 9, 2026
5
Liverpool
I'm in the UK and undecided on a ColorVu or Hybrid model.
Obviously specs are slightly different
8Mp 4K 1/1 2 sensor to 4Mp 1/1 8 . to name a few.
It's only for a yard (see pic) not sure if the DS-2CD2387G2-L(U) is overkill and not really suitable and that a G2H‑ would give a better video at night having less resolution and a better suited CMOS.
Happy to hear from the experts and also open to alternatives with similar specs around the same price .1000030884.jpg
Photo taken from 2m will mount 2.5 to 3m. Any issues I may encounter with it being such a fov to capture. I believe you can have modes like corridor to view narrow spaces.
Usual need the best for capturing clear nighttime images
Thanks
I've been told to always go with a 1/1.2 sensor as it will let more light in , and works better at night . Is that the case and if so if would have to be a 8mp camera as the 4mp is only 1/1.8. I'd be better if with a hybrid as don't intend on leaving the white led on all night
The larger sensor does zero good if it doesn't have light.
All cameras need light, either visible or infrared.
A 1/1.8" 4MP with infrared will beat a 1/1.2" 8MP with no light all night long.
Yeah but isn't the 1/1.2 cam getting it's light from built in , It just has to stay on all night , with no ambient light available.
Think I confused it .
By day full colour view , at night IR mode ( would still capture good quality pics of peeps). But to have this in colour the cameras white light will active upon motion.
I do have the odd motion detected solar light setup too.
But you would advise on getting the smart Hybrid..
Looking at this model now
Hikvision DS-2CD2347G3-LI2UY(Black) 4MP Smart Hybrid Light with ColorVu 3.0​
I don't want to buy a camera that gives me white fussy unidentified images in IR or can't give me full colour at night
Right, but many people don't want to use the built-in white light as it looks out of place or for a variety of reasons and they think the camera will be able to still see in the dark.
To not get fuzzy images, you need a least a 1/120 shutter at night. The faster the shutter, the more light that is needed. The IR will be more than enough.
Cheers I intend to use both (color and IR) on the hybrid model. it's only 1/1.8 though.
My last cams where was a Reolink 820a 843a and wasn't great at night ..
