I have been scouring the forums and Google reverse image search for a couple of hours today and haven't found the solution yet for a project to mount two cameras back to back using one HikVision WML (Wall Mount Long). Pelco used to have an adapter (1-41H8S) that would tee off the single wall mount to allow you to mount two dome cameras as shown in the following picture.
(I'm looking for the horizontal bar between the two cameras only)
I want to do something similar but using the HikVision turret cameras and the PC135H pendant caps.
I have scoured the HikVision / Vivotek and Dahau sites under accessories but haven't found anything similar so short of trying to find a local fab shop to make a one off I'm hoping the collective experience here on the forums will have some ideas of where to find something similar.
I have been told that the fittings on the WML and pendant are probably 1 1/2 inch NPT and while I could fashion something out of black or galvanized gas piping that doesn't meet the aesthetic for this project.
I did find the AXIS T94V01C Dual Camera Mount but short of picking one up and trying to mount a camera on it I can't tell if it will fit on the WML or if the turret cameras (135 mm) will fit on it. It is also a little pricey at over $100 (can) each. If my local supplier had any in stock I'd go to the store and see if they all fit together.
Anyone have a similar problem and how did you solve it?
