So I followed the instructions and wired it all up.
First off, there was confusion in the instruction regarding the little box that I had to install at the chime.
One picture showed black wire to trans white wire to switch, and another picture showed the opposite. Does it matter which one goes where? Or is the wiring for this box reversible?
Second, now that it's all hooked up. The mechanical chime isn't working. So in the app I have options for mechanical or electrical chime. If I choose mechanical, nothing happens. If I choose electrical (with 5 seconds delay), I get a DING, then 5 seconds later I get a DONG. Any shorter interval will not ring the chime. So for now, I've padded the chime with some foam, so I don't get the DONG 5 seconds later. Not ideal, but will have to do for now, unless any experts out there can tell me what's wrong.
Thirdly, if I set the app to give me notifications on motion, the thing does a loud BEEP sound every time there is motion triggered. Is there a way to turn that off? I've disabled it for now because I can't have it beeping off through out the night.
Forth, I've set up the NVR to record on motion on the doorbell, but seems it's not triggering. I've copied all the same settings for my regular POE cameras. Do I have to do something different to make it record on motion? Perhaps I'm doing something wrong relating to the motion detect?
TIA
TIA
