In my current scenario I have 4 NVR
3 are the same, model: DS-7616NI-E2/16P with firmware: V3.4.106 build 191009 on all 3
and a fourth NVR model: DS-7616NXI-K2/16P with firmware: V4.82.100 build 240606
On one of the computers I installed the IVMS4200 to be able to see images from cameras from the 4 NVRs all in one display, however after installing the IVMS the liveview and payback of the 3 NVR model DS-7616NI-E2 / 16P stopped working (only on this computer if I access it from another machine it works) only the NVR model: DS-7616NXI-K2 / 16P continues to work, I noticed that the 3 NVR of the same model use the web components plugin to work on the web, while the NVR that works uses the web plugin, I already tried to reinstall the plugin and it didn't work, I wanted to know what I can try to do to solve this problem, if anyone has had this problem and managed to fix it
