Hi all,
I am a newbie with IP cameras and I'm trying to figure out the setup I'm going to build. After a lot reading in the forum I decided to go for Hikvision NVR (7608NI-I2 or 7608NI-E2) and cameras.
In my setup I'll need an IP video doorphone for the property entrance capable of cooperating with the NVR. I found out that Hikvision has some models but there is little to no information about them online. They can be found to only a few shops online and in the Russian Hikvision site:
https://translate.google.gr/transla...kvision.ru/products/door_station/DS-KV8X02-IM
An online shop:
http://bkgrupe.lt/en/catalog/listing/?id=384
In particular I'm interested for one outdoor unit DS-KV8102-IM and an indoor station DS-KH6310-W
Any of you guys has any experience with these?
They seem pretty similar to Dahua videophones and as they are a lot easier to find, is there any benefit from choosing the Hikvision ones? Provided that the NVR will be a Hikvision.
Also in both Dahua and Hikvision there is the option for opening the door with a RFID card.
Are these access cards included?
Can a similar type of card be bought from aliexpress for example and be activated in IVMS or someone must buy them from Hikvision?
Finally I realize that there is the possibility of founding them only with Russian Region firmware. Is it compatible with European & Western Region NVRs?
Thanks in advance
An online shop:
Thanks in advance
