- Nov 19, 2015
- 2
- 0
Hello all. New to the forum. So I justpurchased and am in the process of setting up new IP POE Hikvision camears witha Hikvision NVR.
I'm using a Hikvision DS-7700 Series NVR. My plan is to have 2 of my 10 cameras have two-way audio. One will be outside at the front door of myhouse underneath the eaves (protected from the rain) and the other will beinside the living room.
I purchased the following two cameras to experiment withthe two-way audio: DS-2CD2432F-IW, and DS-2CD2532F-IS.
With the first one (2432 – Cube) I thought that all youhad to do was plug in the cat5 cable and that single cable would provide thepower, data connection, AND two-way audio. When using the IVMS-4500 app on our phones, we can hear the audio comingin, however when we click on the mic on the bottom, and start talking, we donot get any audio coming out of the camera. I thought this cameras is supposed to have a built in speaker andtherefore would play our audio when talking into the smartphone on the app, am Imissing something?
With the other camera (2532) I understand there is nobuilt in speaker, and from reading the posts I see that I would have topurchase a one-way self-amplified speaker and plug it into the pigtail on the camera,is this correct? Which connection on thepigtail does it go into? Does this meanits just one singe wire that connects from the pigtail to the speaker, and Ishould be able to talk over the speaker through the app? Where do I find such a speaker? What are they called?
Thank you very much.
