- Dec 31, 2016
- 1
- 0
Hi,
I'm trying to use a HIKVISION DS-2CD2042WD-I (V5.4.4 build 161125) to guard my front door.
When the camera detects a 'movement' he should
--> launch recording on my Qnap TS251+
and
--> he should push a notification to my smartphone
so far for the goal...
I tried these scenarios:
--> Enable "Motion Detection" ('Basic Event") on the camera, and linkage by "notify surveillance centre" --> does the trick with Surveillance Station from Qnap (recording and pushing notification) but al lot of false alarms, mainly at night (IR)...
I tried 2 days playing with different configurations (Normal, Expert, Sensitivity, Areas,...) without achieving a real good result.
--> Enable "Intrusion Detection" ("Smart Events") and linkage by "notify surveillance centre" --> does not work, nor for recording to SS, nor for push notification to Surveillance Station... but the "Intrusion Detection" on the camera looked promising.
--> So I stopped working with Surveillance Station and created a SMB/CIFS share on the TS251+ as an HDD (NET HDD) on the camera to where the camera can record to when an intrusion detection is triggered --> recording works fine but only viewable/exporable in Hikvision software (web interface, Hik-Connect, EZVIZ)
AND the push notification triggered by smart event "Intrusion Detection" still doesn't work, even not in Hik-Connect, EZVIZ..
(I tried also IVMS4500 but coudn't realize a good connection via DDNS (mainly also problems with smart events), cloud p2p works but then I can't configure an alarm from such cloud p2p device)...
Now because of lack of a good push notification I configured an "email notification" on the camera --> works fine without false alarms but the delay to receive the mail is sometimes horrible
(configured an other "mail sound" when I receive a mail from the camera)
or me it remains bizar a "smart event" can trigger sending mails but can't trigger a push notification..
conclusion:
--> smart event: intrusion detection triggered by camera
--> recording on the QNAP (SMB/CIF) triggered by intrusion detection camera
--> no push notification... :x but sending a mail triggered by intrusion detection camera (other notification sound in mail app)
--> explore video with EZVIZ on my smartphone
--> explore video with web interface on desktop
It works but it is not really the real thing... and a real disadvantage is the delay of the mails.
some body better / other / simpler ideas?
Thanks in advance!
and
conclusion:
Thanks in advance!
