Hi there
Sadly I have to report that the new Accusense G2 4K camera I got today is secure boot. Dahua went this route recently also.
Unless a workaround is found that pretty much prevents modification if you prefer proper root shell access, running what you want on your camera etc. That's a real end of an era for me as I started buying Hikvision cameras precisely because I had access to them and customize them to meet my needs (and satisfy my curiosity!). Also it will make it harder for security researchers to double check Hikvision products/updates.
Looks like applies to the bootloader, minisys and the kernel (i.e. they have to be signed otherwise the previous link in the chain won't boot it). Presumably a sign of things to come.
If you are a "normal" user then it likely won't affect you. If you are like me then it's time to consider alternatives.
