H6h7h8 n3wb Jul 16, 2019 13 1 Irl Dec 16, 2019 #1 Hi do you only need one poe cable for a hikvision ptz if you are using a poe injector Thanks
Mike Staff member Mar 9, 2014 3,003 2,866 New York Dec 16, 2019 #2 H6h7h8 said: Hi do you only need one poe cable for a hikvision ptz if you are using a poe injector Thanks Click to expand... Yes Reactions: H6h7h8
