- Mar 18, 2017
- 61
- 5
High, I have a Hikvision DS-7108-SN/P PoE NVR and 4 DS-2CD2132F-IS 2.8mm domes.
I've finally got round to playing with the settings regarding night vision, and am getting terrible IR bleed. Possibly due to reflection.
So bad, I've actually turned off the IR on each camera.
I don't really want to run more power (or cables at all, if I can help it) so am looking to see if I can find any PoE IR or White Light Illuminators.
So far, I've found GJD Clarius using 802.3at, and Raytec Vario 2 using 802.3af (same as my NVR I believe).
Is it possible to split the Cat5 so that 1 cable could power both the light and camera? Would it have the power to do so?
Alternatively, is this actually possible? Can I run a 12v item from the DC jack on the camera?
I found it while searching other things.
If that is possible, then it may bell be the simplest solution.
Powering a Hik 2032 bullet with 48V PoE, I get 12V OUT on the cam's 12V power plug.
IE, the cam itself is acting as a 12V pass-through. Dunno what sort of load it could handle, tho.
