- Oct 27, 2017
- 1
- 0
Hey,
I have issue with live stream and record on pcnvr 4200, both are stopping. To "fix" it i need to restart the Storage Service process, but it can work 10 min or 10 days without stopping again. When i check the service it's there working nor "not responding" or something.. and still uses CPU and RAM. The issue is with 2 servers
When I firstly installed the pcnvr it worked fine without any problems maybe 3-4 months with the same count of cameras.
Server 1 have 3 HDDs ( 1 -6TB, 2-TB, 3-2TB) and 20 cameras
Server 2 have 1 HDD (6-TB) and 14 cameras
Both NVRs are: v.1.03.06.02
both are running on virtual machines with 12 CPUs, 6GB Ram
server 1 is installed on Windows server 2012 R2 Standard (x64)
server 2 is installed on Windows Server 2012 Standard (x64)
I've tried to Reinstall the pcnvr software - and it didn't help, also formating the HDDs, reinstalling the OS, i tried also "restarter" to monitor and restart the process, didn't help too.
I've ran out of ideas, please help.
This is log from sever 1:
Code:
2017-10-30 08:26:53 recv command id = 110154
2017-10-30 08:26:53 NETCMD_GET_IPCORECFG_V40.
2017-10-30 08:26:53 recv command id = 110160
2017-10-30 08:26:53 recv command id = 111070
2017-10-30 08:26:53 [CNetService::NetCmdExeThread] NETCMD_GET_WORKSTATUS_V30.
2017-10-30 08:26:54 recv command id = 1110c2
2017-10-30 08:26:57 recv command id = 10200
2017-10-30 08:26:59 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:26:59 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in heartbeat really) deviceid = 19, m_CurrentRecType = 8
2017-10-30 08:26:59 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in ) deviceid = 19,posttime = 5
2017-10-30 08:26:59 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 8,
2017-10-30 08:27:00 recv command id = 110154
2017-10-30 08:27:00 NETCMD_GET_IPCORECFG_V40.
2017-10-30 08:27:00 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MORS DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:27:00 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 8,
2017-10-30 08:27:00 recv command id = 110160
2017-10-30 08:27:00 recv command id = 111070
2017-10-30 08:27:00 [CNetService::NetCmdExeThread] NETCMD_GET_WORKSTATUS_V30.
2017-10-30 08:27:00 recv command id = 1110c2
2017-10-30 08:27:01 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 6, IP = 10.100.32.242, chanelnum = 1
2017-10-30 08:27:01 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:05 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 9, IP = 172.16.200.131, chanelnum = 1
2017-10-30 08:27:05 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 9
2017-10-30 08:27:05 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:05 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:27:06 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 6, IP = 10.100.32.242, chanelnum = 1
2017-10-30 08:27:06 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:13 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 5, IP = 172.16.201.166, chanelnum = 1
2017-10-30 08:27:13 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 5
2017-10-30 08:27:13 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:13 [CSysIntigrate::TrigerAction] trigger alarm sound
2017-10-30 08:27:13 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:27:15 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 9, IP = 172.16.200.131, chanelnum = 1
2017-10-30 08:27:15 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:17 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 2, IP = 10.100.24.240, chanelnum = 1
2017-10-30 08:27:17 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:20 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 9, IP = 172.16.200.131, chanelnum = 1
2017-10-30 08:27:20 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:21 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 10, IP = 172.16.200.175, chanelnum = 1
2017-10-30 08:27:21 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:22 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 10, IP = 172.16.200.175, chanelnum = 1
2017-10-30 08:27:22 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:22 [CSysIntigrate::TrigerAction] trigger alarm sound
2017-10-30 08:27:22 recv command id = 10200
2017-10-30 08:27:23 [CRecordModule::HeardBeat] stop Record????idevid = 2
2017-10-30 08:27:23 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:27:27 recv command id = 10200
2017-10-30 08:27:29 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 15, IP = 172.16.201.164, chanelnum = 1
2017-10-30 08:27:29 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:32 recv command id = 10200
2017-10-30 08:27:35 [CRecordModule::HeardBeat] stop Record????idevid = 15
2017-10-30 08:27:35 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:27:39 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 4, IP = 10.100.8.50, chanelnum = 1
2017-10-30 08:27:39 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:40 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 6, IP = 10.100.32.242, chanelnum = 1
2017-10-30 08:27:40 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:40 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 4, IP = 10.100.8.50, chanelnum = 1
2017-10-30 08:27:40 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:41 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 3, IP = 10.100.64.151, chanelnum = 1
2017-10-30 08:27:41 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:27:43 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 6, IP = 10.100.32.242, chanelnum = 1
2017-10-30 08:27:43 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:45 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 3, IP = 10.100.64.151, chanelnum = 1
2017-10-30 08:27:45 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:27:49 [CSysIntegration::DeviceReconnect] start reconnect to the Device IP = 10.100.70.98,nDevID = 16
2017-10-30 08:27:52 recv command id = 10200
2017-10-30 08:27:58 recv command id = 10200
2017-10-30 08:28:00 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 2, IP = 10.100.24.240, chanelnum = 1
2017-10-30 08:28:00 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 2
2017-10-30 08:28:00 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:28:00 [CSysIntigrate::TrigerAction] trigger alarm sound
2017-10-30 08:28:00 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:28:09 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 1, IP = 10.100.18.209, chanelnum = 1
2017-10-30 08:28:09 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 1
2017-10-30 08:28:09 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:28:09 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:28:23 recv command id = 10200
2017-10-30 08:28:24 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 15, IP = 172.16.201.164, chanelnum = 1
2017-10-30 08:28:24 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 15
2017-10-30 08:28:24 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:28:24 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:28:27 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 1, IP = 10.100.18.209, chanelnum = 1
2017-10-30 08:28:27 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:28:28 recv command id = 10200
2017-10-30 08:28:33 [CRecordModule::HeardBeat] stop Record????idevid = 1
2017-10-30 08:28:33 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:28:35 recv command id = 30000
2017-10-30 08:28:35 [CNetService::NetCmdExeThread] NETCMD_TCP_PREV.
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[13].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel13 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[13].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 13: netConnMem slot 0, pNetConnect = 0xf5024b0
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[10].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel10 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[10].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 10: netConnMem slot 1, pNetConnect = 0xf5024ec
2017-10-30 08:28:35 [CNetService::NetPrevSendThread] enter prw send data thread
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[18].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[17].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel18 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel17 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[18].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[17].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[11].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 18: netConnMem slot 2, pNetConnect = 0xf502528
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel11 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 17: netConnMem slot 3, pNetConnect = 0xf502564
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[11].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 11: netConnMem slot 4, pNetConnect = 0xf5025a0
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[12].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel12 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[12].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 12: netConnMem slot 5, pNetConnect = 0xf5025dc
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[14].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel14 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[14].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 14: netConnMem slot 6, pNetConnect = 0xf502618
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[15].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel15 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[15].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 15: netConnMem slot 7, pNetConnect = 0xf502654
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[9].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel9 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[9].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 9: netConnMem slot 8, pNetConnect = 0xf502690
2017-10-30 08:28:35 [CNetService::NetClientPreview] before m_pChanConnec[8].byLinkchan is 0
2017-10-30 08:28:35 [CNetService::NetClientPreview] channel8 linknum = 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] after m_pChanConnec[8].byLinkchan is 1
2017-10-30 08:28:35 [CNetService::NetClientPreview] Chan 8: netConnMem slot 9, pNetConnect = 0xf5026cc
2017-10-30 08:28:36 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 15, IP = 172.16.201.164, chanelnum = 1
2017-10-30 08:28:36 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:28:37 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 7088,chan is 8
2017-10-30 08:28:37 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 7088
2017-10-30 08:28:38 [CNetService::NetPrevSendThread] ErrExit!
2017-10-30 08:28:38 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 8 linknum = 0
2017-10-30 08:28:38 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 5964,chan is 9
2017-10-30 08:28:38 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 5964
2017-10-30 08:28:38 [CNetService::NetPrevSendThread] send data failed
2017-10-30 08:28:38 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 9 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 6828,chan is 10
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 6828
2017-10-30 08:28:39 [CNetService::NetPrevSendThread] send data failed
2017-10-30 08:28:39 [CNetService::NetPrevSendThread] ErrExit!
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 10 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 6916,chan is 11
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 6916
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 11 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 6676,chan is 12
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 6676
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 12 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 7164,chan is 13
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 7164
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 13 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 7068,chan is 14
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 7068
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 14 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 7148,chan is 15
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 7148
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 15 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 6976,chan is 17
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 6976
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 17 linknum = 0
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread] readn() failed, nread = 0 ,error code is 0,socket is 6512,chan is 18
2017-10-30 08:28:39 [CNetService::NetPrevCtrlThread]---leave Net Preview Control Thread socket is 6512
2017-10-30 08:28:39 [CNetService::NetPrevSendThread]---leave Net Preview Senddata Thread,channel 18 linknum = 0
2017-10-30 08:28:39 recv command id = 30000
2017-10-30 08:28:39 [CNetService::NetCmdExeThread] NETCMD_TCP_PREV.
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[1].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel1 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[1].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[19].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 1: netConnMem slot 0, pNetConnect = 0xf5024b0
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[0].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel19 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel0 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[19].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 19: netConnMem slot 1, pNetConnect = 0xf5024ec
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[0].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 0: netConnMem slot 2, pNetConnect = 0xf502528
2017-10-30 08:28:39 [CNetService::NetPrevSendThread] enter prw send data thread
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[2].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel2 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[2].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 2: netConnMem slot 3, pNetConnect = 0xf502564
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[4].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel4 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[3].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel3 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[4].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[3].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[5].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 4: netConnMem slot 4, pNetConnect = 0xf5025a0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel5 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[6].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 3: netConnMem slot 5, pNetConnect = 0xf5025dc
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[5].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel6 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[6].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 5: netConnMem slot 6, pNetConnect = 0xf502618
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 6: netConnMem slot 7, pNetConnect = 0xf502654
2017-10-30 08:28:39 [CNetService::NetClientPreview] before m_pChanConnec[7].byLinkchan is 0
2017-10-30 08:28:39 [CNetService::NetClientPreview] channel7 linknum = 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] after m_pChanConnec[7].byLinkchan is 1
2017-10-30 08:28:39 [CNetService::NetClientPreview] Chan 7: netConnMem slot 8, pNetConnect = 0xf502690
2017-10-30 08:28:42 [CRecordModule::HeardBeat] stop Record????idevid = 15
2017-10-30 08:28:42 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:28:47 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 1, IP = 10.100.18.209, chanelnum = 1
2017-10-30 08:28:47 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 1
2017-10-30 08:28:47 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:28:47 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:28:53 recv command id = 10200
2017-10-30 08:28:54 [CSysIntegration::DeviceReconnect] start reconnect to the Device IP = 10.100.70.98,nDevID = 16
2017-10-30 08:28:58 recv command id = 10200
2017-10-30 08:29:01 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:29:01 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in heartbeat really) deviceid = 19, m_CurrentRecType = 8
2017-10-30 08:29:01 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in ) deviceid = 19,posttime = 5
2017-10-30 08:29:01 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 8,
2017-10-30 08:29:02 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 15, IP = 172.16.201.164, chanelnum = 1
2017-10-30 08:29:02 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 15
2017-10-30 08:29:02 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:29:02 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:04 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MORS DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:29:04 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 8,
2017-10-30 08:29:08 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 7, IP = 10.100.32.234, chanelnum = 1
2017-10-30 08:29:08 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:29:10 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 7, IP = 10.100.32.234, chanelnum = 1
2017-10-30 08:29:10 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:29:13 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 13, IP = 172.16.201.187, chanelnum = 1
2017-10-30 08:29:13 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:29:15 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:29:15 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in heartbeat really) deviceid = 19, m_CurrentRecType = 8
2017-10-30 08:29:15 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in ) deviceid = 19,posttime = 5
2017-10-30 08:29:15 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 8,
2017-10-30 08:29:15 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MORS DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:29:15 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 8,
2017-10-30 08:29:19 [CRecordModule::HeardBeat] stop Record????idevid = 13
2017-10-30 08:29:19 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:23 recv command id = 10200
2017-10-30 08:29:26 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:29:26 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in heartbeat really) deviceid = 19, m_CurrentRecType = 8
2017-10-30 08:29:26 [CRecordModule::SetRecordState] close REC_MOT_OR_ALM(close in ) deviceid = 19,posttime = 5
2017-10-30 08:29:26 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 8,
2017-10-30 08:29:28 recv command id = 10200
2017-10-30 08:29:32 [CRecordModule::HeardBeat] stop Record????idevid = 19
2017-10-30 08:29:32 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:32 recv command id = 10200
2017-10-30 08:29:33 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 13, IP = 172.16.201.187, chanelnum = 1
2017-10-30 08:29:33 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 13
2017-10-30 08:29:33 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:29:33 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:38 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MORS DevieceID = 19, IP = 172.16.201.167, chanelnum = 1
2017-10-30 08:29:38 [CRecordModule::SetRecordState] start REC_MORS deviceid = 19 m_CurrentRecType = 8
2017-10-30 08:29:38 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 8,
2017-10-30 08:29:38 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:40 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 3, IP = 10.100.64.151, chanelnum = 1
2017-10-30 08:29:40 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:29:45 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 15, IP = 172.16.201.164, chanelnum = 1
2017-10-30 08:29:45 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:29:46 [CRecordModule::HeardBeat] stop Record????idevid = 3
2017-10-30 08:29:46 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:49 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 7, IP = 10.100.32.234, chanelnum = 1
2017-10-30 08:29:49 [CRecordCtrl::SetRecordStatus] bRec = 0, RecType = 2,
2017-10-30 08:29:49 [CSysIntegration::processMsg] Stop SetRecState STORAGEREC_MOTION DevieceID = 10, IP = 172.16.200.175, chanelnum = 1
2017-10-30 08:29:50 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 10, IP = 172.16.200.175, chanelnum = 1
2017-10-30 08:29:50 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:29:50 [CSysIntigrate::TrigerAction] trigger alarm sound
2017-10-30 08:29:52 [CRecordModule::HeardBeat] stop Record????idevid = 15
2017-10-30 08:29:52 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:53 recv command id = 10200
2017-10-30 08:29:53 recv command id = 110154
2017-10-30 08:29:53 NETCMD_GET_IPCORECFG_V40.
2017-10-30 08:29:53 recv command id = 110160
2017-10-30 08:29:53 recv command id = 111070
2017-10-30 08:29:53 [CNetService::NetCmdExeThread] NETCMD_GET_WORKSTATUS_V30.
2017-10-30 08:29:54 recv command id = 1110c2
2017-10-30 08:29:55 [CRecordModule::HeardBeat] stop Record????idevid = 7
2017-10-30 08:29:55 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:55 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 3, IP = 10.100.64.151, chanelnum = 1
2017-10-30 08:29:55 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 3
2017-10-30 08:29:55 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:29:56 [CSysIntegration::processMsg] Start SetRecState STORAGEREC_MOTION DevieceID = 7, IP = 10.100.32.234, chanelnum = 1
2017-10-30 08:29:56 [CRecordModule::SetRecordState] start REC_MOTION deviceid = 7
2017-10-30 08:29:56 [CRecordCtrl::SetRecordStatus] bRec = 1, RecType = 2,
2017-10-30 08:29:56 [ProcessCommunicateSender]WriteProc write type is 3
2017-10-30 08:29:58 recv command id = 10200
2017-10-30 08:29:59 [CSysIntegration::DeviceReconnect] start reconnect to the Device IP = 10.100.70.98,nDevID = 16
2017-10-30 08:30:00 recv command id = 110154
2017-10-30 08:30:00 NETCMD_GET_IPCORECFG_V40.
