Hi guys, I have two hikvison cameras ds-cd2632f-is, both cameras were working fine but two days ago when I was playing with the setting of one of them (I used the ip address of the camera to see the settings) I changed the http port form 80 to 1080 and i enabled the dhcp option for this camera, don't ask why I did that but I did it and since then I cant see that camera in my ivms 4500 neither if I try to use the ip address of the camera in my browser. The sadp tool can see both cameras, the camera I changed the settings shows up for a few minutes and disappear and then comes back. When I tried to change the port or modify anything for this camera it said "time out" inth sadp tool.
I used the Hikvision password reset tool but I keep getting me a code that makes the password recovery failed, I copied and pasted the serial number that get from the sadp tool and the date from the column (I restarted the camera several times and I get the same date which it todays date) every time I use the sadp tool.
Today I reset the button in the camera hopping that this will get the camera back to the original settings where the port was 80 instead of 1080 but it didn't do anything the only thing it changed was the ip address and I'm still not able to make any changes using the sadp tool. I tried the sadp tool with my other camera and I was able to generate the correct code and reset the password. I'm not sure why it doesn't work on the camera that i changed the settings. please help!
