Hikvision Offline IP camera does not exist
umechan
Feb 6, 2024
2
1
Portland
Greeting forum members,
I'm having problems retrieving live views from my NVR plugged cameras. I've researched and tried to set the camera to manual instead of play and plug, but I don't know how to find the correct IP address to my cameras. I'm assuming the current cameras are plugged into the NVR, so they are not IP cameras? Also in SADP, it said my device is active, so I'm trying to find out what went wrong here. Please see attached screen shots.
Also I tried to change IP address of the NVR (currently 192.168.1.17) to 192.168.252.x but it would not work. It said parameter modification completed but when I refresh, nothing happened. There is a mismatch in IP addresses between the actual NVR (192.168.1.17) and the cameras (192.168.254.x), I am not sure how to change that.
Thank you all for help!
Connect to PoE port with your laptop(You will enter NVR NIC2 for PoE devices), factory restore cameras that does not work and plug them back 1 by 1.
