HI
I have a hikvision DS-7608 and 4 Hikvision 2CD2085G1 4k POE cameras and one foscam running via ONVIF.
I have a problem with one of the Hikvision cameras, it keeps cutting out. The thing is I don't think it's a power issue because the camera that over seeing the back door is much longer and it runs fine.
Now I suspect it's the philex junction box I used to join two cables together because I ran out of cable. It did say it was cat5e rated however
Has anyone else successfully ran a cable run with a junction box and still had their camera working?
If so could you recommend a junction box I can use?
Or shall I just replace the entire run?
Any advise will be much appreciated
