- Oct 20, 2015
- 65
- 9
Hello all.
I'll start with my problems;
That's basically it, but my first point is really the driving force here. It infuriates me that I cannot just skip through events (motion, intrusion, etc) from the previous day without loading up the monitor + mouse in the room where the NVR is located.
My solution depends on answers to some questions;
Do newer generation Hikvision NVRs solve this problem? Note that I do not need PoE function.
I'm sure Blue Iris would solve this problem as well, but that may turn out to be the most expensive solution and perhaps it would come at a cost of other features.
Attached are my products.
- My NVR (7608NI-E2) displays event tags on playback when directly operating the NVR. I cannot see event tags when playback is through any other method; Phone with iVMS-4500 or PC with iVMS-4200 or PC through web interface.
- My NVR supports only H264+ and I would like to upgrade that. (2 of my cameras support H265 and 2 support H265+)
