Is the camera unreachable via it's web GUI or other access check, or is the NVR dropping the connection to it?Occasionally a camera goes offline and I need to reboot the NVR.
I had a DS-2CD2432-IWS that would stop responding every few months and need to be power-cycled via the PoE switch admin interface.
I updated the firmware from the 5.3.0 to the last 5.4.5 version and it's never stopped since, last started over a year ago according to it's uptime status.
What's the camera model, and what's the firmware version?
If it's old - there may be a fix to take advantage of.
So it's a camera problem, not an NVR problem?The camera occasionally drops the connection to the NVR.
8.1.5 Reboot
/System/reboot
General Resource v1.0
PUT
Administrator
Description It is used to reboot the device.
Query None
Inbound Data None
Success Return hik:ResponseStaus ResponseStatus
Notes:
ResponseStatus is returned before the device proceeds to reboot.
How would this be a reboot script ? This is a timer that shuts off the NVR and restarts it. Shutting it off this way is a bad idea unless you don't care about possible HDD corruption.A "reboot script" like this will work with any unit and firmware.
The bad part is that you are down for at least a minute; you can program it to shut down power daily, for example from 4:59 to 5:00, or whatever time suits you.
