Greetings,
I have NVR ( DS-7608NXI-I2/8P/S(C) ) at the office, but HDD (WD Purple 10TB PRO) is so loud, so im thinking to buy a Synology NAS which will be located in another room with this disk attached. Can this NVR work with NAS storage EXACTLY THE SAME as if disk would be SATA connected ? Additionaly, i would add some SSD (maybe WD Red SA500 2TB ) as "redundant disk" into NVR. I couldnt find much about redundant disk, but, if i add NAS disk as "primary" and SSD as redundant and, for example primary will be off for last 5 days, will this last 5 days be on "redundant" with all smart events etc like as if it was on primary ? What about exceptions, does "HDD failure" exception on NVR include NAS being off, or unreachable ? Will primary then sync with redundant after being "returned" ?
Thanks.
Thanks.
