I have an nvr that i have hooked up to my network switch. It got assigned an IP. 192.168.1.28
It then created a subnet with ips ranging from 192.168.254.1/254 for the cameras.
Since these are nested and can not be directly accessed from LAN(192.168.1.x) you have to setup something called virtual host.
I also did that and it generated HREFs ( ports match to the cameras) in camera management page
But when you click those links they are dead. So either non of these cameras have webserver(which I know they do because when I can connect to them by plugging my laptop to one of the POE sockets on NVR and go to 192.168.254, I can log into the cameras setup page) Or NVR is not doing the routing right.
Do I need to setup a NAT or something ?This should have been really easy installation but it is giving me such a headache.
THanks in advance
THanks in advance
