I have been using hik DVR integrated with my home assistant through ONVIF. I am able to get footage of the DVR on Home Assistant but that's about it.
Recently I bought a hik IP cam and hooked it up to Home Assistant (ONVIF) and I notice the ip cam ONVIF outputs WAY more info / sensor values than DVR. There is processor speed, motion detection sensor value, up time, etc.
Does anybody know what a hik NVR ONVIF outputs? I never had hik NVR, only DVRs and ip cam. I am wondering if the NVR also outputs the same vast amount of ONVIF data as the ip cam.
