Dealing wih a bizzar error with my Hikvision NVR 7616NI-E2 - for whatever reason, it automatically adds 30 minutes for 3 of my 5 cams with EVERY possible time setting (2 cams display time as set/expected, 3 cams show 30 min more than set/expected).
Interestingly enough, one of the 2 cams showing time correctly is a 2732 on FW 5.35 - my other 2732 on FW 5.35 is showing 30 min plus.
What I have checked so far:
1) It is definitievely coming from the NVR - when I switch the NVR off, my cams keep the time as set (NTP or manual setting)
2) Whatever I set in the NVR time setting (tried different time zones, DST offset, NTP and manual settings), 3 cams display 30 min more. If I add a DST offset of 30 min, the 3 cams show correctly, and of course the 2 other ones lag 30 min behind.
3) Since I thought it is a NVR firmware problem, I upgraded from 3.4.91 to 3.4.95 - no difference. I then downgraded back to 3.4.90 - no change.
4) I have reset the NVR - again no difference.
I am out of ideas now. Obviously, this problem is substantial as in a situation where one needs the recordings, consistent time stamps are critical.
I would highly appreciate, if anybody has any ideas or advise!
