Hi all,
Just a heads up for those of you who access your Hikvision NVRs via Safari on a Mac - currently, there seems to be an issue causing both the Live View and Playback to fail.
Early stages at the mo' so I haven't been able to nail down all the versions it affects, but currently we've had a number of reports (and tested ourselves) that the issue affects the below software versions:
To fix the issue, change the transmission protocol of your NVR from TCP to UDP.
Via a web browser, navigate to Configuration >> Local in order to do so.
Hikvision are aware of the issue, and a fix is in development for release in November.
If anyone has any feedback or experiences with the issue above (or the lack of an issue at all) then it's always appreciated.
- Safari v9.1.2 build 11601.7.7 and later
- OS X El Capitan v10.11.6 and later
- Web Components plugin for OS X v3.0.5.43 and later
- Hikvision -E, -K and -I series NVRs
