- Jul 24, 2015
- 5
- 0
Hi,
I have recently purchased 1 DS7608NI/E2/8P NVR and 3 DS2CD2T32-I5 cameras. I have had terrible trouble getting the camera's to work with the NVR. When I first got the cameras I plugged them into the POE ports of the NVR and thought that the plug and play feature meant that they would work out of the box - This still isn't working.
I have managed to get the cameras working now (see below) but I would like to know if anyone can explain why the plug and play feature isn't working.
First I had to plug the camera into my router and connect it to an external power supply (otherwise it wouldn't show in the SADP software). Then using the SADP software on the disc that came with the cameras I 'activated' the camera, set a admin password and then set the IP address to one of the addresses that the POE ports have allocated - 192.168.254.2/3/4 and set the gateway for the cameras to the router - 192.168.87.254. Interestingly the SADP software that I downloaded from Hikvision didn't have the activate feature which was frustrating, nor does the OSX version of iVMS-4200 (which I was initially using).
Once I done this, I had to connect the camera to one of the POE ports, and then on the NVR set that ports Camera settings to manual mode, and then change the IP address of the port to that of the camera connected, and enter the admin password - If I left it in plug and play mode it would never detect the camera/connect to the camera.
Is this what I should be doing ?
For information the firmware versions are:
NVR V3.0.10
Camera 5.3.0
I feel that this my be a firmware issue of the NVR, would it be sorted by upgrading the firmware - If so, where is the best place for me to get the latest firmware from??
I look forward to some advise,
James
NVR V3.0.10
Camera 5.3.0
James
