Hello guys,
Just installed a Hikvision ds-7616-ni-e2, all cameras connected and showing up on the dvr.
Im having a problem making thr nvr work with Hiddns. All the cameras are individually configured to work with Hiddns, and they work fine, with some NAT issues on the router limiting the number of NAT entries.
Hiddns server picks up the nvr, domain is confgured ok.
Upnp is enabled, ports are assigned automatically and picked up by Hiddns. And show up as valid in the nat settings on the nvr.
The external ip shows up as blanks on all ports in the nat settings on the nvr.
When I add it on IVMS, it recognises the domain but shows up as connection failed, while I can connect to the cameras individually through hiddns fine.
Can't access it through the webpage through the Hiddns address too.
What might be the issue here?
Sent from my D6503 using Tapatalk
