- Feb 27, 2015
- 31
- 2
I had various Hikvision cameras running on a QNAP NAS, recording motion triggered events into Surveillance Station. I am moving them to a Hikvision DS-7616NI-E2 / 8P running firmware V3.4.95 build 170626. My primary camera is a DS-2CD2132F-IS, which acts as my doorbell by notifying iVMS-4500 on my phone.
The event settings on the cameras are way better than the event settings in this NVR, which has no expert setting for multiple areas, and no sensitivity between 0 and 20. Unfortunately, the NVR's settings override the cameras' own settings. If I adjust the cameras from their individual pages, it's all good for a while, but eventually the NVR settings replace them and I'm back to getting spurious triggers from headlights and such.
I tried running one of the cameras ONVIF, but the NVR switched to recording it nonstop. I tried turning off motion detection in the NVR, which turned it off in the cameras, and then turning it back on in the cameras, but the NVR didn't record.
How can I get the cameras' motion sensitivity controls to stick?
