It actually is setted up to same password, loltry setting the camera to the same password as the NVR
Have you specified the 'ONVIF port' as shown in ONVIF Device Manager? Sometimes it's not 80.Trying to set it up with cisco 6930 via onvif but no results. It is saying “incorrect login or password”
I try to access network parameters from onvif device manager and it says that ntp is not supported by serverHave you specified the 'ONVIF port' as shown in ONVIF Device Manager? Sometimes it's not 80.
Have you tried if it will connect via RTSP using a Custom protocol, using the RTSP string from ONVIF Device Manager?
The 'ONVIF port' can be seen in the URI at the bottom of the Identification panel.Have you specified the 'ONVIF port' as shown in ONVIF Device Manager? Sometimes it's not 80.
The RTSP string can be seen at the bottom of the Live Video panel.Have you tried if it will connect via RTSP using a Custom protocol, using the RTSP string from ONVIF Device Manager?
Its 554, i tried to connect it with custom (1-4) and it says that “no video link”The 'ONVIF port' can be seen in the URI at the bottom of the Identification panel.
554 will be the RTSP port, not the 'ONVIF port'.Its 554, i tried to connect it with custom (1-4) and it says that “no video link”
My bad,554 will be the RTSP port, not the 'ONVIF port'.
So its probably 80 because nvr detects 80 port no matter what and also it is not shown in uri554 will be the RTSP port, not the 'ONVIF port'.
Well the obvious answer is that you're using the wrong credentials to connect.“incorrect login or password”
Transmission Control Protocol (TCP) port on which the IP camera receives
Real-Time Streaming Protocol (RTSP) commands. You must configure this
port if you want to allow third-party devices or software to access video
streams from the IP camera.
RTSP is a standard for connecting a client to control streaming data over the
web.
Valid values are 554 and 1024 through 65535. The default port is 554.
Click Save to be redirected to the login page. After login, ONVIF service
starts working.
Yes, that's correct, if the ONVIF port is 80, it's not shown in the URI.also it is not shown in uri
I can access onvif device manager or web. And no, i didnt create specific account for onvifWell the obvious answer is that you're using the wrong credentials to connect.
Does the camera have its own web confirmation page that you can access and confirm what credentials are used for onvif?
Did you create an account specifically for onvif?
But i am not trying to connect it with rtsp, only with onvif. So What should i do?The manual says this about rtsp.
Bold added by me.
It says this about onvif.
Again bold added by me.
I have found possible issue. Time in my camera is wrong.Well the obvious answer is that you're using the wrong credentials to connect.
