HikVision NVR don't see the ip cams -SOLVED-
Hi to the forum, this is my first post
I've completed an ip cams setup using the following items
NVR: HIKVISION DS7608Ni-E1 http://www.hikvision.com/europe/products_show.asp?id=9868
CAMERA: DS-2CD2232-I5 (2 pieces) http://www.hikvision.com/en/us/products_show.asp?id=9120
POE SWITCH: TL-SG1008P 8 port (4 port POE) http://www.tp-link.it/products/details/?categoryid=233&model=TL-SG1008P
The poe switch is located 30m away from the modem router of my ISP company and connected to it through a CAT5e cable
The NVR is connected to the poe switch via a NON poe port through CAT5e cable
The two ip Cams are connected to the poe switch via POE ports through CAT5e cables
The problem:
I can reach the cameras and the NVR in my lan by tiping the given ip in the browser
192.168.1.10 for the nvr
192.168.1.71 1st camera
192.168.1.72 2nd camera
BUT the NVR doesn't see the two ip cams even if I add manually the two ip addresses of the camera
Any helps from someone that uses a similar setup?
Thanks in advance, Emanuel
The problem:
