Hello everybody, hope you can hellllllppppp!
I have the HIKVISION DS-7608NI-E2-8P-A
The crux of what I am asking is – on the basis of the Onvif Protocol thing will my VNR be compatible with DaHua Camera (esp PTZ function)
I ask because I am in the process of getting a camera – I like the Dahua cameras. I wish I had known this before purchasing Hikvision NVR. I hate that fan it is OTT as I don’t even use the built in POE’s.
Now then, I really like the Dahua IPC-HFW2300R-Z as from the YouTube vid it appears to even pick up registration plates (not sure if it is due to good lighting conditions or the camera angle). Currently it is available for purchase for about £100.
http://www.dahuasecurity.com/uk/download/R Series Vari-focal Megapixel Network Camera.pdf (SPEC LINK)
Alternatively there is the DaHua IPC-HFW4300R-Z with exactly the same specs but a bit cheaper, available for purchase for about £75 and based on customer feedbacks it is also popular (no idea what is going on there or which model was first).
https://www.aliexpress.com/store/product/Dahua-IPC-HFW4300R-Z-2-8-mm-12-mm-zoom-lens-electric-3-megapixel-network-camera/1282343_32364173670.html
I am guessing that the model number with the higher numeric value is the newer or version possibly for Chinese or other market – there is also no user pdf manual or marketing material for the DaHua IPC-HFW4300R-Z.
But to confuse matters even more there is the Dahua DH IPCHFW2300RP-Z; again same spec.
There are a couple of vids by putin
I cannot seem to find anything in the Hikvision that appeals as well or has the same popularity as there are no youtube vids videos showing their performances.
The closest I can find spec wise from Hikvision is DS-2CD2642FWD-IZS (twice the price at £229)
http://www.hikvision.com/en/Products_accessries_160_i5599.html
http://www.ebay.co.uk/itm/HIKVision-4MP-WDR-Vari-focal-Bullet-Network-Camera-DS-2CD2642FWD-IZS-/142078912465?_trksid=p2141725.m3641.l6368
The camera will be fitted under eave at about 10 feet height overlooking driveway. Would really appreciate your input, thank you.
