alastairstevenson Staff member Oct 28, 2014 16,409 7,175 Scotland May 1, 2020 #21 Unfortunately the downgrade block will inhibit the ability to install earlier versions of firmware that allow password extraction. What models are the cameras?
Muskilz n3wb Apr 30, 2020 9 0 Nairobi May 1, 2020 #22 alastairstevenson said: Unfortunately the downgrade block will inhibit the ability to install earlier versions of firmware that allow password extraction. What models are the cameras? Click to expand... Hik vision ip cameras
alastairstevenson Staff member Oct 28, 2014 16,409 7,175 Scotland May 1, 2020 #23 Have you checked if the cameras have a reset button?
Muskilz n3wb Apr 30, 2020 9 0 Nairobi May 1, 2020 #24 alastairstevenson said: Have you checked if the cameras have a reset button? Click to expand... Nop they dont have
