alastairstevenson
Staff member
There may well be a clue in the kernel log about events preceding the shutdown - however I don't think in that version of firmware you have the full telnet access - can you confirm?
If you did, or if you had a serial console connection, you could hook up something like PuTTY to keep a running view of kernel events.
At the telnet command line,
cat /proc/kmsg
would show events in the kernel's ring buffer.
For serial console access, just leave PuTTY running.
As far as I know, there isn't a kernel log on the NVRs that survives a reboot.
cat /proc/kmsg
