Folks,
I noticed that when I rebooted and started the SSH access on the NVR, that it appears that the host key changed. Is this expected behavior?
$ ssh [email protected]
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
SHA256:JW2aQFMFeufRc/zAR3yUy9IegEkEgCUr45wigduBE1s.
Please contact your system administrator.
Add correct host key in /home/<user>/.ssh/known_hosts to get rid of this message.
Offending RSA key in /home/<user>/.ssh/known_hosts:118
RSA host key for 192.168.1.22 has changed and you have requested strict checking.
Host key verification failed.
Of course I can just delete the key in .ssh/known_hosts but kind of annoying.
Also, is there a way to enable ssh via the ISAPI interface? It appears that SSH is just a one time use and you have to re-enable it every time you want to access it.
Thanks,
-J
Thanks,
-J
