Hello!
I'm trying to replace old no-name NVR to HIkvision 7604 and i'm need to solve a next problem.
There are 4 old chinese IP-cameras (Wapa made it) BL5C*** series with onvif support.
Their are streamed in "Onvif device manager" and "iSpy" without any problem, but when I'm try to recieve stream from the same rtsp link (rtsp://[ip address]:554/mainstream) in Hikvision NVR or VLC, i'm get only the first frame and pictures don't moving any more. When i'm reconnect to the stream in VLC, i'm see another first frame and image is freezing again. In VLC statistics i'm saw that VLC can decoded only the first block in Wapa's stream.
Can I'm connect that cameras to Hik's NVR bypass 3d part codecs or does a some another way exist to play/record that strange streams?
