Hi all
I will try ro write english correctly
I have a DS-2DE3304W-DE camera connected to a TPlink 4G router (TL-MR6400). It works perfectly because I use "cloud hik" platform.
But I just bought a better and bigger (used) camera DS-2DF6223-AEL .
If it works perfectly in local mode (using local IP) , impossible to get it working in 4G mode and, also, there is no platform mode option in camera setup (no firmware update for this too).
First: is it really possible (with no fix ip) ?
I know a lot of things in electronics but not for ip solutions .
Actually I tried to get the "old" camera working without platform access (so I'm sure if it work it will be probably the same for the other one) but with no success, even other other camera is off.
If someone can explain me how to do ...
Thanks for help
Thanks for help
