Hi I’ve got a couple of questions regarding a install I was asked to do. 19 cameras. 16 cams plugged into the nvr the other 3 connected to a switch with the switch connected to the nvr and another switch for internet. my questions are?
1, is this the best way to set up
2, the 3 cams on the switch had different IP range to the cams on nvr. with different gateways I assume the buildings network switch has set these IPs. Should I have set the cams to the same as the nvr cams? These 3 cameras are disconnecting every so often would this be a ip set up issue.
thanks
thanks
