I have a HikVision mini dome (2542 US version) that has line alerts setup that constantly stop working. I've had the camera for 2+ years (purchased from a reputable US seller) - the line alerts will work for several months, and then just stop (the camera and recording continue to work fine).
In order to get the line alerts working again i usually have to go into the camera and disable/re-enable line alerts and sometimes re-configure the line alert drawing (a simple reboot usually does not work).
I'm suspicious that Synology Surveillance station updates/reboots are messing with my camera settings. I've tried using a non-administrator hikvision user to connect to my cameras to Surveillance station however they can't be activated on Synology without admin permissions.
Here's some info on my setup, any advice would be appreciated:
Model : XC-2542FWDI
Firmware: V5.4.5 build 170124
NVR: Synology Surveillance Station 8
Switch: POE
The Line alerts work flawlessly in my setup when they are working, it's just any guess as to when they will stop functioning.
Model : XC-2542FWDI
Switch: POE
