I have a Hikvision NVR-208-E/8P it's firmware is on v3.4.92 build 170794 - I am using IVMS 4200 v3.13.1.5 build 20250805 downloaded from the Hikvision website. I've also tried version IVMS 4200 2.5.0.5 - I have just gone ahead and reset the password for the admin user on the NVR system, using the SADP tool - I had to email a file to hikvision which they responded back with a key. I was able to successfully reset the password, when I created the password I did not enter any symbols. Just letters and numbers.
I am able to login to the NVR system via IP address on a web browser using the same details I just reset. However when I try and use IVMS 4200 either the latest or an old version, on my Windows 11 PC, IVMS 4200 says that the username or password is incorrect. When I use the SADP tool to change a setting eg to turn DHCP off / on, and I enter in the same password I use on the iVMS software, it works. I have tried adding another user in the Web Portal for the NVR and tried logging in on the IVMS 4200 software, however that hasn't worked. I tried setting the port to 8001 and that still produces the Username or password incorrect error. I have set windows to allow inbound and outbound port for TCP 8000. I have reinstalled IVMS 4200 multiple times, I've installed it on a computer that hasn't had the software before and same issue. I've clicked Restore in Maintenance on the NVR and that hasn't worked at all. I've rebooted this NVR multiple times. However same issue of the iVMS software saying username or password incorrect.
Please help.
Please help.
