- May 11, 2018
- 1
- 0
Hi,
I'm having an issue with playing back storage on my cameras.
Setup:
1 x NVR DS-7604NI-K1/4P
2 x DS-2CD2385FWD-I 8MP Turret Cameras
1 x 2TB Purple WD HD
All cameras are PoE into the NVR which has PoE ports...
Network to view is through 300Mbps LAN.
This is what happens on motion detection:
It also stutters nearly EVERY time it picks up motion, the recording will skip from 1 sec to 4 sec then play fine then freeze frame and jump to 10s which makes it a nightmare for playing back video.
I can't playback any media through the web client either as it's just a GREY screen or fails:
Playback also fails through the webpage:
There is also no display through the Web NVR menu:
Any help would be much appreciated!
Setup:
